SPV Parts
Greenwood IN
F-150 Raptor, Ranger Raptor
We have the NEW 2025 Pig Tail adapters now IN STOCK.
We designed these so you can connect to EITHER switch they send back there. Or both. So if you just want your backlights on a second Aux switch, you can.
https://specialtyperformanceparts.c...-switch-to-spv-harness?variant=47656677146856
Quick note. Rigid is delayed again. As usual. We do have literally a handful of these SRL lights on hand for shipment immediately. But after that, it will be mid October before Rigid says they are on hand again.
Here is the full kit. Including the updated 25 Pig Tail harnesses.
https://specialtyperformanceparts.c...t-plug-n-play-srl?_pos=2&_sid=831ed6126&_ss=r
Feel free to call or text us-
317/934/6778
info @spvparts.com
SPV Parts
Greenwood IN
Quick note. Rigid is delayed again. As usual. We do have literally a handful of these SRL lights on hand for shipment immediately. But after that, it will be mid October before Rigid says they are on hand again. We have hundreds on order from them.
317/934/6778
info @spvparts.com
SPV Parts
Greenwood IN
@SPV Parts - do you have a strong recommendation for amber rigid ditch lights on the Trailhunter
As in are you asking if I would recommend them in general, like quality wise? or if I can basically point them out?
The Rigid 360's are great lights.
I need to bundle them, but in the mean time... here is your 3 course meal..
Pick the brackets here-
https://specialtyperformanceparts.c...lar-bracket-rigid?_pos=7&_sid=275e6cb9b&_ss=r
Then pick the Harness here... (On the A-Pillar Harness... For Round Rigid 360's, Rigid Radiance/Scene.. Choose "add on connectors". For D-Series and Side Shooters Choose "DT 2 Way Adapters") You don't need a relay adapter with the A-pillar harness for the four inch 360's, Radiance, Scene or Normal D series on a 10 amp switch as long as its at least 10 amps.
Last, pick your lights- ( I do prefer the 360 series on there and you can choose the AMBER PRO 4" ones.)
https://specialtyperformanceparts.com/collections/individual-pod-lights
(This search more easily shows the Amber Pro versions or add on covers)
https://specialtyperformanceparts.com/search?type=product&q=rigid+amber+pro
If you want to pick out your 3 items and email it to us at info @spvparts.com (fastest) then we can put a custom cart together for you with a "bundle" discount.
When I have time, I will try to just put some preassembled ones on the site. For now though, we will make sure you get the best bundle price.
Tacomonkey
Geoff
J Town, NJ
TRD pro
I finally installed mine a couple weeks ago and found this flexible extension to be very helpful. Still hoping someone can figure out how to tie into the bed lights so these will fire when you unlock the truck
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation 20250910_190539
Has anyone found that the little crappy plastic screw receivers inside the ARB bumper can strip easily?
SPV Parts
Greenwood IN
I can probably help with that.
You just may need to send a few pictures.
There should be a connector on the back of one of the bed lights.
Rubenc87
Ruben
2025 TRD PRO
I'm glad that I got my order in when I did. I did not have to lower the spare tire however I did remove the small speaker located in front of the passenger side bumper light cover. Here is the pic of the speaker in question. I only needed the factory wire in kit for the rear switch and the jumper. The only issue that I had was by my own doing, I didn't make a good connection between rear end plug and the reverse light connector (red wire) easy fix. .
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation IMG_4505 2
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation IMG_4530 2
Rubenc87
Ruben
2025 TRD PRO
Of the three plugs, one goes to the pigtail which eliminate the connector that is on the harness with the ground wire attached (bottom right packed wire). As far as installing the lights, just use a long extension and you will be fine aside from the small skpeaker (pictured). .
How did you tie everything up to the frame without dropping the tire? I’m kind of dumb with stuff like this so I would not be surprised if I’m the only one who dropped the tire.
Rubenc87
Ruben
2025 TRD PRO
Ran the wires above the spare between spare and bumper. Just follow the factory wiring. Once everything is tested then just zip tie to factory wiring.
