Mild Rattle or Ticking Sound Drivers Side Interior.
Fiigtaco
24 TRD OR
Looks like resolution was already reached and it was a different rattle - here’s where mine was (clip came undone - probably from power wash)
The air flow would cause this to flap and tap - I secured it and all solved
think this is the same on my truck, how’d you end up securing it?
GMak621
Røgue Valley
26 Tacoma TRD ØR Hybrid
I have tried everything in this thread to fix the rattle with no luck. It sounds like it’s in the dash somewhere. Driving me crazy
me crazy
Did you try putting your hand on the dash speaker - or did you check the plastic trim piece inside the wheel well
GMak621
Røgue Valley
Yes I have. Here is also what I’ve done:
I fixed the splash guards that were loose, added tape to the rear fold down seat latches, took driver side door panel off and taped all the connectors from moving, I peeled back the driver door weather striping and added padded tape….fml
Oh shit .. ok you’ve exceeded my level … where exactly do you think you hear it coming from
hongerrr
2024 Tacoma Trail Hunter
holy shit.. you just saved me a lot of stress.. came here to search and this is exactly where mine came from. Secured it and finally driving with a big smile.. thanks taco team!!
DuckBlind
Spokane
24 Tacoma TRD OR
Just picked up a new Tacoma 2 days ago. Was curious if anyone has experienced a mild rattle or ticking like noise on the drivers side door or b-pillar area. I cannot figure out what it is or could be but it is in that general area. It’s is not heard during most driving except when going over rougher patches of road or something would could more sharp jarring of the truck rather than something like a speed bump. I cannot tell if it’s outside the door/b pillar area or inside. It sounds like it’s literally like right in your face if I ride in the back side and put my ear close to that area but I can’t seem to put my finger on anything. May have to go to dealer but really didn’t want to. It’s minor but noticeable enough to be mildly annoying.
I had the same rattle and have tried everything to find it and I just found it TODAY! So, the bottom of the seatbelt (where it connects at the bottom of the B and C pillar) has a small plastic covering, take these off! It originally sounded like it was over left shoulder but I finally tapped these and it made the identical sound. Quickly popped all four off and fixed!
Muckle
You get a ticking sound, you get a ticking sound, everyone gets a ticking sound!
