Anyone with a PRO or TH install ditch lights? I find that my light bar throws a ton of flood but wondering if anyone has significantly enhanced their light profile with ditch lights. I may take advantage of the sale this weekend at SPV.
TFOUTS
Timothy
Northwest Florida
Months back I installed white Rigid pod (ditch) lights, mounting brackets, and wiring harness all from SPV. The white is a near identical color to my Ice Cap colored Trailhunter. The ditch lights are wired to AUX 2. My profile photo shows from the outside and here's a cab photo looking out to the right. It was a very simple install. Since the Trailhunter (Rigid) light bar spreads straight out and then to the sides, I aimed the pod lights to start where the light bar ends. It is about a 175 degree lighted pathway. NOTE: it is a very tight fit opening the hood with the light on the snorkel side, so be very careful when opening. I actually turn the pod light facing inward.
2024 Tacoma New Rigid Lights for ARB Steel Rear Bumper Screenshot 2025-08-30 at 11.41.14
SPV Parts
Greenwood IN
F-150 Raptor, Ranger Raptor
We have the NEW 2025 Pig Tail adapters now IN STOCK.
We designed these so you can connect to EITHER switch they send back there. Or both. So if you just want your backlights on a second Aux switch, you can.
https://specialtyperformanceparts.c...-switch-to-spv-harness?variant=47656677146856
Quick note. Rigid is delayed again. As usual. We do have literally a handful of these SRL lights on hand for shipment immediately. But after that, it will be mid October before Rigid says they are on hand again.
Here is the full kit. Including the updated 25 Pig Tail harnesses.
https://specialtyperformanceparts.c...t-plug-n-play-srl?_pos=2&_sid=831ed6126&_ss=r
Feel free to call or text us-
317/934/6778
info @spvparts.com
SPV Parts
Greenwood IN
UPDATE! - !2/1/2025 We have these back in stock!
We have filled all the backorders today and have about 30 or so left.. So if this is something you want.. Get your order in now!
(Below is a Previous Post) Links are valid but the update above supersedes Octobers stock comments)
317/934/6778
info @spvparts.com
So as of right now, we do still have 6 remaining of these lights/kit in stock until the next shipment from Rigid in mid October.
So if you are wanting them before that, I would jump on it quickly.
info @spvparts.com
fstamm79
Florian
Richmond, VA
2025 TH
John,
I just ordered the Rigid lights with your harness bundle.
A question: it would be cool if the two red lights would also serve as additional blinkers. As of now, that is not one of the options, right?
Thank you,
Florian Stamm
tipsyjam
Hawai'i
fstamm79
Florian
Richmond, VA
2025 TH
