Ran the wires above the spare between spare and bumper. Just follow the factory wiring. Once everything is tested then just zip tie to factory wiring.
Yeah. It’s just a very tight fit.
Rubenc87
Ruben
2025 TRD PRO
I did use a creeper which made it easy. I was able to slide from light to light even under the spare tire with no issues.
5bassman
Kennesaw, Ga
2025 Toyota Tacoma Pro Mudbath
I finally finished up with the wiring on these lights for my 2025 Tacoma Pro following the instructions closely. Everything works as it should but for some reason mine turns on manually using Aux 3 instead of Aux 1. From what I’ve read these lights only draw 1 amp and Aux 3 is 5 amps so I should be good but I’m wondering what I did wrong. Is there more than one 4 pin to 2 pin jumper under the hood? Or is it possible that I hooked up the white wire to the plug that plugs into the back of the truck but didn’t need to according to instructions since I received the pigtail that goes into the tail/parking light. I would unwrap it to check but since it’s working fine in Aux 3 I just want to make sure I’m ok. Thanks!
Rubenc87
Ruben
2025 TRD PRO
The pigtail that I used for the rear is using AUX 4. The pigtail is in the bag with two pigtails in the same bag. The paperwork that is included with the pigtails shows the amp draw from each colored wire and I wired the ground to ground and the 10 amp to the red wire (main light) iirc. the white wire would be for the outer red halo light and is not required
Rubenc87
Ruben
2025 TRD PRO
the pkg on the top row all the way to the right. yellow outline on paperwork.
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation IMG_4534 2
