Oil/Fuel Dilution Concerns...
Between oil changes, does your engine oil and level:
  • Non-Hybrid: Remains at the full mark
    Votes: 12 40.0%
  • Hybrid MAX: Remains at the full mark
    Votes: 9 30.0%
  • Non-Hybrid: Oil level increases over time
    Votes: 0 0.0%
  • Hybrid MAX: Oil level increases over time
    Votes: 4 13.3%
  • Non-Hybrid: Fuel smell on dipstick/oil
    Votes: 1 3.3%
  • Hybrid MAX: Fuel smell on dispstick/oil
    Votes: 5 16.7%
  • Non-Hybrid: NO fuel smell on dispstick/oil
    Votes: 6 20.0%
  • Hybdrid MAX: NO fuel smell on dipstick/oil
    Votes: 6 20.0%
  • Total voters
JayZap
Weston, FL
2025 Tacoma Trailhunter
In these engines, the oil pressure starts to build as soon as the starter turns the flywheel, or motor/generator turns the crank. The ECU won’t allow the engine to fire up until minimum oil pressure parameters are met first. The oil pump is primed and the oil system is at minimum pressure to start before the engine is allowed to start.
Gotcha, this makes sense to me, thank your for explaining this.
Oil pressure is relatively instantaneous
Watch the oil pressure gauge in the instrument display. As soon as it is visible it is already at full pressure - instantaneous as @JayZap said.
crepr12
NEast
2025 Limited Hybrid
On my second oil change with 6300+miles ...I drain and add 5.9 and keep it moving...I guess I should be checking the oil level...
32spoke
Jason
Petaluma,CA
Cold engine oil will do this.. is it the same after driving for 30 minutes, looking at that same oil pressure at a stop light?
32spoke
Jason
Petaluma,CA
Engine still cranks from a zero oil pressure, hence the engine bearing are made from soft metal alloys to provide a buffering effect until oil pressure and volume create the protective oil film layer. Great news, engines are lasting longer than ever before, so the engineering is improving, looking at average vehicle life is continually increasing.
Good question because you are right that I was talking about a cold start. My engine stops all the time once it is warm. so I will let you know.
32spoke
Jason
Petaluma,CA
An oil analysis will advise you if engine bearing/babbit
Oil analysis will show if you have babbit/engine bearing traces that are higher than average. Using lake speed jr’s oil analysis will provide an legit pathway for verifying any concerns you may have.. like comparing engine bearing/babbit material in the oil for a hybrid be non hybrid t24a-fts engine…if you have a hybrid with start/stop.. you can likely eliminate the start stop option, also help turbo charger life “IF” the start stop shuts an engine down immediately after a highway run, or stomping on the loud pedal..no matter what, enjoy the truck!
The only work around start/stop with hybrids is tow/haul mode.
32spoke
Jason
Petaluma,CA
Or an aftermarket software change…I chose to avoid an hybrid option… not to rub anyone’s nose in it. I just desired to eliminate risk and long term expense.
wire4money
Tim
Las Vegas
2024 Ice Cap SR5
Interesting. Figured the inline A.S.S eliminator would work as it does with any other vehicle, which is just by simulating a press of the off button.
Hybrid doesn’t have a button.
james cole
Bronco
I checked my oil on my hybrid… smells like gas and also checked the oil on a V6 Tacoma that I have and it smells very similar… just a heads up…
