Tire pressure screen reset - when will there be a TSB?
bsquaredMTB
Ben
El Paso, TX
The fact that Toyota can't get a full solution to fix this issue is INCREDIBLY stupid. I agree with that. The solution we've described does work (for most) but that's not a "complete" solution that a vehicle, especially at this price point, should be dealing with.
stuckinsocal
24 TRD OR 6MT
@stuckinsocal @bsquaredMTB
Still doing something different. I did the following the other day, but sure enough when I got in the truck the next morning, it had rolled back to Trip B and never put itself back even after the truck had said the profile was loaded.
  1. Engine running, in park, parking brake active
  2. Settings | Profiles, delete primary user
  3. screen reverts to "Guest - Get Started"
  4. Re-link vehicle via VIN/QR code, select "activate"
  5. Vehicle reports "all set", click "complete"
  6. When prompted to set up Bluetooth, selected "No"
  7. Setting | Info | Security, system reset = yes
  8. confirm for system reset
    1. This immediate de-linked the vehicle and associated account from steps 4/5
  9. Vehicle screen returns to Guest - Link Vehicle prompt
    1. Selected to "cancel setup"
    2. Message box with "profile not saved"
  10. Prompted to pair mobile device, selected "No"
  11. Left infotainment on Profile screen and began to configure the MID
    1. As I was moving around the MID menus, the vehicle infotainment refreshed and showed my old profile name
  12. Configured Gauge settings first, and configured Dials settings second
    1. On MID screen 1
      1. Allowed all dials to be permitted on left side (this pertains to all screens)
      2. Configured MID 1 (navigation left, fuel economy right)
    2. On MID screen 2
      1. Allowed all dials to be permitted on right side (this pertains to all screens)
      2. Configured MID 2 (trip A left, current drive right)
    3. On MID screen 3
      1. Configured MID 3 (trip B left, TPMS right)
  13. Connect Bluetooth, confirm pair, allow Android Auto
  14. On Infotainment, tap to Profile
    1. Noticed a "SAVE" text next to profile name
    2. Tapped it / profile name
    3. Prompted to confirm save (have never seen this before)
    4. Selected "Continue"
    5. Screen flips to "Get Started - Link Vehicle" prompts
      1. Have to perform entire VIN/QR link again, activate, decline additional
      2. Receive "All Set" / completed prompt
    6. Prompted to set up Bluetooth, selected "Yes"
  15. Powered truck off
  16. Powered truck back on
    1. All MID displays are back at defaults
    2. Configured everything again per Step 12 above
  17. Within Settings | Personal Info
    1. No devices linked
    2. No key linked
    3. (YET, I get the "welcome... profile loading" message on start up)
  18. Powered truck off
  19. Powered truck back on ~10 min later
  20. Did not auto-find my profile this time (full cold shutdown), displayed "Guest" as active profile
  21. Tapped my saved profile name, prompted me for my PIN
  22. Entered PIN and received "welcome... profile loading"
  23. Powered truck off
  24. Powered truck back on < 10 min later
  25. "Profile loading"
  26. Powered truck off, waited overnight
  27. Powered truck on, "Guest" loaded
  28. Tapped my profile, entered PIN
    1. dials remained rolled over to Trip B, not TPMS
  29. Activated device linked to profile and key linked to profile
  30. Powered truck off, waited overnight
  31. Powered truck on, my profile loaded
  32. Dial remained rolled over to Trip B
    1. Few more drives in and still, even if I want in park (with or without parking brake set) for multiple minutes, never loads dial back to TPMS
It is going to take me a little bit to retrace your steps and think about what may be diffrent, but a quick question - do you turn on your lights at all when you turn on your truck? I did that just recently (haven't driven at night for a little bit since its almost always light in the evening in socal) and it reverted my change (of course once I fixed it next startup was fine) and I realized that anything that changes the dash before the widgets load may cause it to revert. Just a thought.
lights are set to "auto" as their default
While we've collectively been exploring this, I've been pressing start and then not touching or adjusting anything until the infotainment screen removes the "loading profile" message and AA takes over the screen.
stuckinsocal
24 TRD OR 6MT
I don't think this is it, but try setting them to "off". That is how I have mine set. Its going to take me a bit to read though and compare your previous message but I will do so and try to find the differences.
