- First Name
- James
- Joined
- Mar 17, 2025
- Threads
- 0
- Messages
- 66
- Reaction score
- 48
- Location
- The Farm, Central Washington
- Vehicle(s)
- 2024 Toyota Tacoma
I am glad I ordered mine from SPC earlier today expecting such delays. ?
I just wanted to post a note to those considering the SRL lights for their Tacoma.
Rigid is having some supply issues so they will NOT have any SRL lights produced to ship out until at the very earliest LATE May, but maybe Late June.
We have I want to say 8 or 10 remaining flush mount SRL lights left for our plug in kits in this thread, and we have probably 75-100 of them on backorder from Rigid for resupply. However, due to that supply interruption, they won't ship any of those or anyone's out until that May/June time frame. Rigid is out of stock on the lights and their kits. Even though the site says "add to cart" that doesn't mean its in stock. They will just ship them when they have them again. We work closely with Rigid, so this is a little heads up and insight.
So, for those of you who have been on the fence. I am just letting you know. Once we are out of these, it may be a couple months before we can ship any more. So you might want to consider getting them now. Of course that just means you beat the rush.
For those who have shop connections.. All supply chains are out of stock. That includes Keystone, Meyer, Turn 14, and Premier.
We are direct with Rigid. However, many shops buy from the distribution centers mentioned. When those distribution centers are out, that means local installers/Shops have no stock either.
Sorry to paint a glum picture. I am just trying to save a few of you who may be on the fence, that for now. We have a few, but not for long...
Let us know if you need help or have questions.
https://specialtyperformanceparts.c...t-plug-n-play-srl?_pos=2&_sid=26b2ca9f9&_ss=r
Yes, that’s what I have, however I’m still working on getting power to my rear aux adaptor, going to troubleshoot more this evening (yes I have the jumper under the hood connected)Hi John,
I'm sure this has been asked and answered ad nauseam but if I wanted to order these lights for my 2025 TRD Pro, I would order this:
Just wanting to make sure. This will trigger them with the reverse lights and I will be able to toggle them with the AUX switch also? And give me the red running lights when my lights are on? Am I correct on this? Once this is confirmed I will make a purchase of your remaining stock.
I did not, however there shouldn’t be a need to I haven’t run anything, I will check that tonightDid you check the fuse? The 3 aux fuses are under the hood on the drivers side.
I must have missed some replies. Sorry.Hi John,
Good timing!Just purchased this kit! Didn’t want to come up short by the time my truck arrives.
Great to hear!Be sure to check out my review and install video of the Rear Rigid Lights with control from the cab and integrated reverse for the ARB Bumper from Specialty Performance, you guys are awesome!
Insane Rear Lights: MUST-HAVE MOD for Tacoma Trailhunter & TRD Pro! ?
I added it to a playlist on our channel. Hopefully it gets you some more views.Be sure to check out my review and install video of the Rear Rigid Lights with control from the cab and integrated reverse for the ARB Bumper from Specialty Performance, you guys are awesome!
Thanks I appreciate it!Good timing!
Great to hear!
Thanks for the shout outs!
Did you ever get around to doing this?I have my SPC kit for my 2024 Tacoma Pro and saw on the Rigid site that these lights only use 1 amp, which I would assume would be 2 amps for both.
https://www.rigidindustries.com/sr-l-series-off-road-spreader-pod-red-halo-pair-53122.html
I am thinking of changing the rear connector pigtail in the engine compartment to use the white 5 amp wire (AUX3) instead of the original black 15 amp wire (AUX1) which would then free up to use AUX 1 (15 amp) & AUX2 (10 AMP) for other accessories up front in the engine bay or in the interior.
It seems like a waste to use up my 15 amp wire and fuse if not much power is needed. Any thoughts?
Would 5 amps be enough? If it needed a bit more I could use the green 10 amp wire instead.
