Toy-truck
Houston, TX
Not yet, it is on my list of things to do on my Truck and around the house and yard. Honeydo season is here. :sadface:
Keep up updated if you figure something out. I'm agree with you on the 15 amp in the rear is a wasted aux position if it's being used for the ARB rear bumper Rigid lights. I'm thinking if it's possible to just swap the fuse around between Aux 1 and Aux 3 but I am no electrical expert so I don't know if that will lead to any future issue.
JimScotty0
The Farm, Central Washington
2024 Toyota Tacoma
Will do. It has to work. Just wish I had 2 wires in the harness from the engine compartment to the rear which would then open up more possibities like I understand the 2025's have. The 2024's only have 1 wire.
I also have just installed, but not yet connected, a 6 gang AuxBeam Switch which is more then I really need, but I like the pulsing option on a channel when needed. :wink: That would really work nice on both of my 112W 4" cube ditch lights.
My list yet to do is my Fang lights, Grill lights, Hood light, Pod lights with DRL and signals, and my rear ARB bumper Rigid lights with the SPC kit. I have a bunch of inexpensive amber and red 5" lights that I may put somewhere, but not sure where for those yet, if at all.
I am putting together a Visio like wiring drawing for all the hookups in the engine compartment to make it easier to get things right. I am a believer in the 80/20 rule with 80% spent on the planning and 20% on the doing. My 25 years of IT Network Infrastructre Architecture has taught me many lessons working on complex designs in large scale projects. I recently retired, so this should be very easy with the most difficulity being access to hard to reach areas. My 25 year old son, who lives with me, will help greatly with those issues.
SPV Parts
Greenwood IN
F-150 Raptor, Ranger Raptor
These are a great addition to the reverse lights, and should have come from the factory like this. The wire harness from @SPV Parts makes it easy for a rookie like me. One question for John, what is needed to connect to the factory switch on a 2025?
HI Melissa with SPV here we do have a current option for the 25 Model, we are working on a new Pig Tail ONE piece connector to plug into the new 4 pin connector for pass through switches. In the meantime, we're using a simple crimp on connector to apply to your Toyota provided pig tail. This will work the same way.
AnthemAVM
Michael
25 Trailhunter
Do you have the part number that we would need to order?
SPV Parts
Greenwood IN
Here is a link-
https://specialtyperformanceparts.c...ht-kit-plug-n-play-srl?variant=47172873158888
Select 2025, Select the first option "With Oem Switches"
You'll notice on the 25's it's $15 cheaper than the 24's because it has the simple crimp on connector for now that you simply put on your included pig tail from Toyota. From there, you just plug it all together and you will have reverse lights when in reverse. On with a switch as well, and the red backlights with the tail lights automatically.
Do take note. We are waiting for more of the Rigid lights to arrive to complete and ship the kits. Rigid has had supply issues. Those lights the #53222 have been out nationally for a while. We just carry such a surplus normally. Our 3 month old backorders should hopefully arrive within 2-4 weeks. It is still advised to get your order in though because the backorders are racking up. This way you will be first in first out. We hate this and we always carry excessive stock. Unfortunately we are at Rigids mercy on the light portion.
JimScotty0
2024 Toyota Tacoma
Project still in the works, but I did finish the Toyota pigtail jumper.
This is the original Toyota Jumper.
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation 20250422_182221
Unpinned the Black wire (AUX1) and pinned the White wire (AUX3) using a similar pin as used in the Toyota harness.
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation 20250512_164500
I believe this pin is a 621-2-2A
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation 1747291604442-dd
Using my own 3 pin waterproof female connector, I crimped the pins on AUX1, AUX2, and Ground.
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation 20250512_173151
Here is how it looks when finished. I will build a male 3 wire pigtail jumper for future potential use if or when needed and tuck it away. I have no plans for use right now since I will be using my Auxbeam RGB 6 Gang Switch for most of my lighting project which includes ditch pod lights, fang lights, grill DRL lights, and a hood scoop light.
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation 20250512_173847
I am still researching what harness wires to tap for my DRL power and for left and right signals. I tested both engine bay fuse boxes for something that would be powered on with my factory DRL, but could not find anything. I think I will need to go directly to the lamp harnesses. The Pro is different than most of the other models because of the sequential signal lamps on the Pro model which makes the harness and wiring different than the other models.
If anybody knows which harness and/or wires I can tap please let me know.
AnthemAVM
Michael
25 Trailhunter
Here is a link-
John, thanks for your help, but I already bought the lights and harness; I just need the 4-pin connector.
myhikingboots
Chuck
Atlanta, GA
2025 Tacoma Trailhunter
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation IMG_4750
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation IMG_4750.JPG
I just finished installing the kit from SPV on my 2025 Truck and just wanted to add some useful information I received from them. As you can see from the pictures there are 3 wires coming from the Toyota supplied rear harness and 3 on the SPV adapter. White/black being the ground, green 10A, and black 15A on the Toyota wires. On the SPV adapter, black is ground, red is for the backup lights and (ironically) white is for the red halos. I didn't want to be able to turn the halos on with one of the AUX switches, so I did not connect it. You can turn them on with the parking lights, so it seemed redundant to waste an AUX switch for them. I connected the green 10A wire from the Toyota harness to the red SPV wire, and the backup lights turn on with the AUX 4 switch. Hope this helps anyone with a 2025.
SPV Parts
Greenwood IN
Great post!
I was actually just getting ready to create a PDF Supplement for this on the 2025's.
If you don't mind, I would love to use your 2 photos with a shout out since you put the arrows and text on them already. It just saves me that time!
Let me know, and great job!
NukenJED
Richland, WA
2025 Tacoma TRD Pro
Great post!
My 2025 TRD Pro Toyota supplied harness/pigtail has 4 wires, not 3. It also has a white wire (10 amp) which must just be another aux switch inside the cab.
My SPV short harness also has a 3-pole female plugged into the 3-pole male plug that the improvised/interim male plug is to plug into. The female plug has the ground wire attached. Is this not needed now since the Toyota supplied harness has the white/black ground wire?
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation Short Harness
Mightyquinn
Andy
Fayetteville,NC
2025 TRD Pro Ice Cap/Cockpit Red
Yes, you are correct. You can remove the plug with the single black wire as it is not needed for your setup. That single black wire threw me off when I was wiring mine up too.
myhikingboots
Chuck
Atlanta, GA
Yep, that was confusing, and I should have added that to my post. You don't need the single black wire if you are connecting to the aux switches.
NukenJED
Richland, WA
2025 Tacoma TRD Pro
Thanks guys. I appreciate it! I’m glad, since grounds tend to always be the main issue when things stop working.
Does anyone know if the rectangular front Rigid trim pieces can be installed with the lights through the bumper, or must they be left off?
Mightyquinn
Andy
Fayetteville,NC
I left mine out as I couldn't find a way for them to fit in the cut outs.
