Ray T
Ray
24 tacoma pro
Agreed I’m no electronic guru by any means but with some help from SPV and figuring out that I had to get power to the switch from the engine compartment all was hooked up and working properly but it is #4 aux
SPV Parts
Greenwood IN
F-150 Raptor, Ranger Raptor
Yeah it is confusing because I don't have a truck in front of me.
So is this one a power SOURCE? Or is it an INPUT for pass throughs somewhere else in the truck?
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation 1750095376989-mb
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation 1750095406358-a
Because from my understanding THIS one was the POWER OUT from the Aux switches. Which is the Green wire (Aux 2) Black wire (Aux 1) and White wire (Aux 3) with the black/white striped wire the ground?
2024 Tacoma HOW TO: Rigid SR-L Series Lights for ARB Rear Bumper Installation 1750095560429-y4
NukenJED
Richland, WA
2025 Tacoma TRD Pro
I believe the blue sheet connector plugs into the upper plug and supplies loads up front. These are already hot and have power. I think the green sheet connector plugs into the plug inside the cab, and should also be hot. You have to install the jumper harness in the engine bay to power the rear plug. That’s how my 25 Pro with 4 AUX switches should be anyways.
Ray T
Ray
24 tacoma pro
Yes you have to use the pigtail which connects by the washer fluid it is tight tough to get too to connect back wires to the switches
NukenJED
Richland, WA
2025 Tacoma TRD Pro
It took me forever to find the plugs, remove the caps, and install the pigtail jumper. Ugggh.
Ray T
Ray
24 tacoma pro
I thought it was a pain in the ? hard as hell to get your hands down in there!
Franko Manini
Frank
Victoria, BC CANADA
In installed the SPV Parts kit:
SPV Parts 2024 Up Toyota Tacoma (Flush Mount/ARB Bumper) Rigid SR-L Reverse Light Kit Plug N Play SRL
Specialty Performance PartsSKU: 53222TOYOPGT-TL-24
And the quality of their product is amazing. Absolutely wonderful. Their instructions and the harness have been changed slightly since the OP documented the install. SPV included a small card that had a QR code on it for the specific instructions page. That was a huge help.
The install went well and the lights work perfectly and look fantastic.
Hatman
Argyle, TX
2025 Tacoma Trailhunter / 2022 Bronco Badlands
Are the Rigid SR-L lights back in stock? I just ordered my kit but failed to ask if they were even available!
SPV Parts
Greenwood IN
Yes. They have been! If Anyone has been waiting, I must have missed updating you all on here. We have plenty in stock.
larkhen
New Mexico
Accord
Has anyone been able to use the SVP wire harness for the 2024 but instead of having the halo come on with parking lights it comes on instead as a brake/stop light? I’ve heard many here that the red halo is much brighter than the parking lights so I was thinking of ordering the set but maybe changing it to be brake lights
wolfpackwest
wolfpackwest
Paul
It’s not the way the SPV taillight adapter harness works. You’d have to manually move the wiring pin in the harness so the lights are triggered by the brake light wire instead of running light wire. The rigid halo lights are not excessively brighter than the taillights.
SPV Parts
Greenwood IN
Like @wolfpackwest said, but also its more complex than that.
The tail lights have 4 wires...
Ground
Running
Reverse
Brake/Turn Signals
That means if you move the running light wire to the Brake/Turn wire.. it will flash on BOTH sides when you turn on ONE turn signal and not at ALL when you turn on the other.
So it would require 2 tail light adapters and each going direct to each light separately. This also eliminates the switch function unless (and we can) create a patch harness that combines both sides to one with diodes blocking backflow to both sides from each/brake/turn connection.
Daneger
Dane
Muskegon, MI
2024 Tacoma SR5
I do not have the factory AUX switches, but purchased the long lead for the dash switch and the short harness for the reverse light trigger. Where the heck do I plug in the long lead switch?
StreeTaco
2024 Tacoma TrailHunter
I installed my halos to operate as brake/blinkers by wiring them into the 7pin harness. I also used this 7pin to wire the main white LED as reverse lights only. Easy to do, without the mess of the 3rd party harness.
